GapRider, any updates on your ghost tune fix for clutch release idle issue? My buddy is experiencing the same issue.
Attachment 73420
Two things really, I never got the cam tune where I wanted it and haven't messed with it for quite awhile because it still had high IPC, and I don't like how the throttle works overtime trying to constantly adjust for the jerky RPM of the lope idle.
The attached tune is the version I describe and my notes say it had good stability off idle, I haven't re-verified that.
Then this great thread opened up:
https://www.hptuners.com/forum/showt...770#post497770
So now I'm trying to follow what AKDMB is doing which is enabling MP13 and using it for the cam tune. murphie has great info in there trying to explain how mapped points work and that's what I'm trying to do.
I've been playing with cam tune again using MP13 for it.
What I like is that I have a tune that:
- will stay in MP13 during idle
- lopes mildly
- is stable in stop and go traffic, doesn't try to stall or surge when pushing in or releasing the clutch
- throttle movement isn't too erratic for me
Attachment 73525
Attachment 73526
Attachment 73527
Attachment 73528
What I don't like is:
- While idling it stays in Op Stab - Dashpot for Idle speed control mode
- I want it to be in RPM Ctrl (which is fitting for idle, dashpot is for decel)
It does idle in RPM Ctrl for Idle speed control mode and MP13 (which I think is the best) but that is only during Emission Reduction mode.
As soon as it goes to Op Stab - RPM Ctrl, it jumps to MP0 until I blip the throttle causing it to shift to Dashpot for Idle speed control mode which allows it to go to MP13 and start chopping.
What I want it to do is stay in RPM Ctrl and keep the weight on MP13, instead of having it jump to Dashpot. I'd like to do this without "cheating".
I have tried completely disabling every reference to MP0 in the parameters and this only results in it instead trying to weight MP1 while it's in RPM Ctrl.
My head is full right now, you guys care to take a gander and see if you can point me in a good direction?
To Toyoguru do you still have a guide you would be willing to email? Thanks
Cant you just tweak when Op Stability mode kicks in in the enable table? You have load by RPM. Why not just set two top rows of 0 and 1500 rpms a load of 0.01 (essentially locking it out) and then leave stock rest of the table.
Also if you want to make sure you get into RPM control mode, you should probably raise the minimum VSS for idle to 2 or 3mph, And widen the error control range (raise Enable to 250 and disable to 25 or something close to that).
Hey guys. Been playing around with a Ghost Tune for my 17 mustang GT (Australian Model).
After about 10+ hours of playing around i finally got a somewhat stable tune going. I ended up following Gaprider and created a custom MP13 for the Ghost Tune.
For some reason though using VCM Scanner shows that Map Point 11 is being 99% used... Not sure why but it still seems to work.
I used the Snap to Point table and enabled MP13
I then mapped the Optimum Stability 6 to 13
Then in Distance tables i mapped all of my 850RPM column to 6.0
A few other tweaks like idle control and VSS speeds and others and it seems to be quite stable now... It hasn't got as much of a LOPE as i had liked. Any suggestions are welcome!
I only opened my HP Tuners package 1 week ago so learning lots! The ghost tune was my first learning project!
Had a few DTC's to clear like (ABS, Power Steering etc.) but nothing i couldn't find searching through this forum for answers!
Tune posted.Attachment 73758
Just went through this thread.
Can someone that's got the ghost tune mastered post a file?
There are a few good and stable ghost tune cals throughout the forum.
Has anyone successfully done a Ghost Cam with a PD blower?
Will this work the same way on 15-17’s?
Hey guys, I understand how the distance/array/mapped point tables get changed so you end up with a lopey idle. The change I don't understand, is why you seem to need to enable torque based decel. I'm looking to do this on a Control Pack strategy that has Torque Based Decel disabled. It already returns to idle perfectly so I'd like to not change this. What about torque based decel lets the car lope? Ultimately it's the cam timing of the commanded Mapped Point in the cam schedule at idle, that makes the car lope, so what does torque based decel have to do with anything? Is this change a result of those not setting up the tune properly so that the lopey idle mapped point is only referenced at idle, or not appropriately raising VCT limits?
Maybe this is just one of those things in the background we can't seem to see, idk. Ford disables Torque Based decel in the Boss 302 Track Key file with the lopey idle, so it looks like it can be done.
I wanted to do it the 'boss track key' way but was unsuccessful. If you review the tune, you'll see it uses the Emissions distance table for the lope. HP Tuners doesn't have any entry / exit emissions settings (though I REALLY wish they did).
I've done the idle lope in emissions mode and it was awesome unfortunately it exits lol :D
Torque based decel uses distance tables where-as adaptive idle does not (or is another thing we can't see/don't have control over with the HPT).
If you put these two ideas together & add the fact that Emissions mode overrides the other VCT modes (specifically adaptive idle in a stock tune), it's easy to see why Ford used it.
I could be 100% wrong about any of this so take it with a grain of salt as I'm a noob but this is what I believe is going on!
That makes sense to me. I noticed Ford using Emissions Reduction. We can see the tables that define the behavior of the cam schedules but we don't have much control over when the different schedules are active (haven't updated my software in while, they may have added them idk). I will look at making the switch to torque based decel on my strategy then, I wish there was a little more info out there on dialing those tables in.
I need to dial in my torque decel table, my 16 mustang likes to either stalls or rpms jump down so fast when you press the clutch in to down shift for a slow turn or when taking out of gear coming to a stop , rpms will lump way down and either stall or hunt for a idle for several seconds. im hoping that will solve it, just not sure how much to lower it
What's the real advantage here to using dashpot over torque based decel???
I finally have a solid ghost cam tune, never tries to stall (even with AC on)and runs like normal when you touch the gas. I love it
Its a 2013 GT, T56, 4.10 gears with longtubes. No cats because it dumps raw fuel down the exhaust when loping which will cause CAT overheating from trying to burn it all
The more I learned by playing and logging, I found that less parameters needed changing.
Here's what worked for me.
- Set P/N idle RPM to 850
- I use MP8 for the lope at idle, if you change cam angles for any mapped point then the speed density and torque tables for that mapped point will now be wrong so I didn't change any. Using MP8 is done in Op Stab tables explained below
- Idle ctrl mode is in dashpot, not RPM ctrl - setting Idle>General>Min VSS to 0 does this for me. Tap the gas once right after you start the car and it should switch to dashpot idle ctrl (I do have tq decel enabled but I still have all dashpot parameters set to work from my dashpot tune-I don't know if this is necessary)
- The cam lope won't happen until Emission Reduction times out and VCT schedule mode goes to Optimal Stability
- Let Op Stab Mode handle all the lope idle stuff
- Enable MP8 in Snap to Points
- Fill Op Stab Mapped Points table with all 8s
- Op Stab Max load table - set RPM x axis first three values to 750, 1000,1100RPMs and set max load at those RPMs to 0.3, leave the rest at 0.13. This will let it stay in Op Stab at idle only and able to transition to Fuel Econ above idle
- Set Best Drivability Min load table to all 5s to negate it
- I have Airflow>Desired Air Mass>Desired Air Mass Idle Switch Enabled (don't know if this is necessary)
- Spark- this seemed to have affects on two things:
- making the idle chop like I wanted, this takes lower spark advance
- staying on MP8
- lower the spark in the MBT and Borderline tables to 20 for 750,1000RPMs and loads 0.1 - 0.3 MAKE SURE TO CHANGE THOSE VALUES IN THE SPARK TABLES ON EITHER SIDE (SO MP7 AND MP9). THE ECU SEEMS TO ALWAYS LOOK AT SURROUNDING VALUES AND WHEN THEY ARE REALLY DIFFERENT, IT SEEMS RELUCTANT TO SETTLE ON ONE MAPPED POINT.
- Here's where I found a mistake but the car does great. I chose MP8 for the lope idle but I changed the spark values in MP6,7,8 which puts MP7 in the middle. I will go back and target MP7 in the Op Stab table and see how it does.
- Raise the Engine Diagnostics>Misfire Detection>Misfire Test RPM min to 1500RPM
- Idle airflow values are all stock
The car should chop at idle and when you touch the gas immediately smooth out and go to Fuel Econ and follow the fuel economy mapped points progression just like normal.
While cruising it will be in Fuel Econ, when you let off the gas it will go to Op Stab.
Hope I didn't miss anything and if someone wants to target MP7 instead of MP8 let me know how it worked out.
Attachment 92008
Thank you for updating the post
