3 Attachment(s)
First fire and idle 5.3 Turbo on E85 3 bar OS, 40% rich???
Hi all,
I just got this running this week. Started right up and settled into a good idle at 950.
I let it idle for 18 minutes or so while logging. Then lost the data thanks to user error (I hate touchpads!)
While it idled, I was reading AFR on the gas scale and it clearly was rich. Around 10:1.
So I reset everything up to read Lambda. And give me Lambda error. I'm using the config in 1/EQ to show commanded lambda.
Today I did a cold start and logged the data. Didn't F it up this time.
It idles at .7 lambda. Runs well though.
Slow revved to near 3000 holding a bit along the way, same result.
It's running in open loop.
I've double checked the injector data. (ID 1000) at 50psi base pressure.
Looking for a little help.
Here is the log, config and tune
