Help with Active Exhaust valve control on 6th gen Camaro SS
I have a 2016 Camaro SS with the exhaust valves. In HPTuners I see under System > General that's there a Active Exhaust section. Has anyone messed with these to see if it changes when the valves open or close? I want to see if when it's in Track mode I can make them stay open all the time. Stock they will still close even when i'm just cruising at 40mph in Track mode and you have to give it a decent amount of gas for them to open again. I know I can pull the fuse for them but I would prefer to be able to put it in Stealth in the mornings when i leave then Track anytime else. Any help would be great. Thanks.
