What would be the best way to get better fuel milage out of an 05 LLY? What should I change in the tune?
you can play with deceleration fuel cut off DFCO, upshift & downshift & torque converter lockup tables for minor improvements
Quote:
Originally Posted by 06MAX
Any updates on the mileage tune? What kind of gains have you seen?
I have improved my mileage by 3+ mpg, AFE Stage 2 worth solid 1 mpg, Banks turbo Back No kitty, worth solid 1, retuning with my tow tune for optimum driveability, and a real good power increase worth a solid 1 to 1.5 mpg.Quote:
Originally Posted by CRASHNBURN
Still evaluatiing with 947 miles so far.
This is on an LLY Crew Cab Dually 4x4 with Leer Cap and 235-85-R16 tires.
Quote:
Originally Posted by JANNETTYRACING
I have an LBZ & the stock intake is better then the aftermarket one right now. I know the aftermarket ones are much nicer then the stock Chevy one before o6 for sure. So you think you have a 1 to 1.5 mpg gain on programing only? That is not to bad. How much hp are you adding be doing that? Did you in crease you boost & timing to get that?
I have not dynoed it yet because I am focusing on driveability performance first and foremost, then mileage then the numbers, will be what they will be not worried about it because the truck is performing flawlessly at this point.Quote:
Throttle response is smooth and linear, Torque is Fantastic, Shifts are smooth and quick, Smoke is almost non existing, only a light grey haze if you smash the throttle, and getting better mileage to boot.
If I had to take a guess I would say it feels like 80 hp.
I will be picking up my new car trailer this week and will report on towing performance and mileage.
Ted.
80 hp. That is getting close for a 06 stock tranny. I think 85 is safe. Some guys are okay at 100. Some limp there. I used to run my hot juice & smoke at that level & I was okay. How much extra hp can the 05 tranny take? That would be great, if you would share you finding. Please post some numbers on that. Thanks.
I have found that all stock allison transmissions can handle about 375-400 rear wheel as long as the tune is done right and they don't mess with certain tables.
Certain tables cause the TCM to not learn and that causes Limp.
Doesn't that number seem low for such a large transmission?Quote:
400rwhp or ~700ftlb of tq? lol both numbers seem decent for me.
400 rwhp is pretty darn good on a stock tranny. I think the tq. that goes along with the hp is what really does kill it.
For a Stock Trans to handle a 50% increase in power is pretty darn impressive.Quote:
Originally Posted by wide open
It is not the size of the transmission as much as it is the calibration for said transmission.
A recalibrated Allison Trans can handle over 600 rear wheel and over 1200 lb. ft. torque.
Ted.
400 hp alone doesn't sound impressive but you are right considering that a 400 hp diesel is making over 700 fl lb of tq. When it is stated that way it makes sense to me.Quote:
Originally Posted by Bill@HPTuners
Yeah you are right, hp doesn't break parts torque does.:)Quote:
I mentioned the size of the transmission because the thing is freaking huge which presumably is to accomodate the really beefy internals.Quote:
What do you mean be recalibrated? Just a software recalibration or changing hard parts?
Actually its me that breaks stuff...:doh:Quote:
I mean...seriously...I destroyed a 4L60 behind a 4.3 6 cyl and then a 4L80 behind a GenIII 6.0 v8. :D
I hear that! I have destroyed more than my fair share of trannys. I haven't blown anything up with a 4.3 though.Quote:
Originally Posted by gman4dx266
We're trying to find an Ecotec with the Allison to see if Gman can break it... LOL
Sometimes it is just software changes sometimes it is hardware changes sometimes it is both.Quote:
Depends on the Path one chooses to take.
I personlly start with Software changes.
FWIW my 05 tranny limped at +60 hp. It was the low rpm TQ and driver using cruise that would do Torque Converter clutch in when towing heavy. New Suncoast Level IV tranny and TC doesnt seem to mind anything I throw at it.
