just bought the truck last week seems low on power.
just order hp tuners will be here thursday.
2005 5.9
180hp injectors
airdog
s475
85% cp3
fully built transmission manual vale body
625 arp studs
thanks
2005 5.9
180hp injectors
airdog
s475
85% cp3
625 arp studs
thanks
any one ??
If ya don't already have HP Tuners, where did this file come from? Also, not all trucks are created equal even if running same mods and same file. Post a log file. Is it smokey at idle, low midrange, dog up top, noisy, low boost, high EGT, etc. Saying it seems low on power is too broad to really offer any opinion.:cheers:
The kid that tuned it sent it too me . Alot of smoke from 2k under runs decent until then smoke stops and feels like thats all it has. Idle is fine A little hard to start .
Well, that is definitely what the tune shows. It looks like there is no understanding of when and how to apply fuel versus timing. There are a couple of good threads around here about tuning with some good starter files. Stay away from the ones that max all the limiters! Potential for a 5k runaway sitting in your driveway! Anyway, I'm not sure you'll find someone to tune your truck for free. Those guys have spent too much time honing their skills. Start small by adjusting the areas of the map that you perceive as issues. I usually start with timing and then introduce bigger fuel changes. But I'm no expert either!
i need to add fuel from 100mpa up but not sure about timing?
I'm not sure how that tune is even working. Try the stock tune and datalog it just sitting in the driveway. Add to you log "Final Timing Correction Reason".
What gear ratio and tire size do you have?
4.10 factory tire size i think i will check when i get home
tried something different found a tune close to what i have done . pops a let at idle when giving it gas still clears up pretty fast though
Check your messages.
Sent reply
That is the worst tune i've ever seen posted ever..... You're engine is probably on it's way out or already has a melted piston if you romped this tune more than a few times.....
Really haven’t been driving it because of this issue thats why i asked for a little help dont want to melt a piston. The motor seems healthy.
Thanks for your help lol
Honestly most on the forum are people that aren’t familiar with proper tuning themselves and really can’t offer much in the way of help and the small few that are on the forum that do know aren’t going to give much because it’s a business they are in. There are various topics to be found on the forum in regards to some things like timing to fuel but best suggestion overall was above to go back to stock tuning, data log, observe how things work and make small changes till you find what you like or pay a real tuner for tuning and not some kid. I’ve never heard of a runaway engine just sitting in the driveway before just from maxing out rpm limiters
hopefully this is better
Honestly not sure what is even going on in that tune
Very help full lol
