1 Attachment(s)
EGR Enable not visible P59 ECU
Attachment 137668
Am I just not able to enable EGR to run my wideband through?
This is an 05 2500HD 6.0 P59 ecu with 12592618 OS
Is there a better way to log in without messing with the AC system? If not, what wire Am I running the 5v to on the AC system?
Is it possible that HP tuners just removed this option if so can anyone send me a version that I can edit it with or what do I have to do?
So I downloaded an older version of HP Tuners and it has the EGR disable enable shown for the p01 computer sample tune, opened it with the later version I'm using and I am unable to enable or disable it. I think this is BS, If anyone has a copy of the oldest software available that will work with a MPVi3 please let me know I would much like a copy to see If I can make the necessary change so that I don't have to screw around with the AC stuff. And I'm guessing someone from Hp tuners will reply saying they disabled the feature because of "emissions tampering stuff" which is more BS because if it were important for emissions my 05 would still have an EGT, and they could have just made it so that you could enable the EGR but not disable. Seems like they just want people to spend 200$ on the pro set features. Quite irritating since with everything I do with this product I hit a wall and features are disabled or removed. I'm begining to wish I just bough a different product to beging with because this is ridiculous.
1 Attachment(s)
Havinf same issue...trying to log AFR through EGR, no enable button
Attachment 152212
I have attached my tune file. Anyone out there that can help me enable the EGR??? Using a MPVI (old school) on a P59 ECU. Have everything wired up (pin 55 blue connector) have all the math parameters done and channels created. This is the last step so i can start tuning the truck.
Thanks in advance!!!!
1 Attachment(s)
I need EGR enable on 1998 Camaro with 411 PCM
Here is my tune file.
Need EGR enable for 30-0300 wideband.
The wideband works but I have zero voltage in my hp tuner scanner.
Please help.
Attachment 154207
