I havn't noticed much of an issue with this transmission after being rebuilt, but now since my fueling and TQ tables are more inline from the dyno, I am getting a 2-3 bind/tie-up. I did remove the wave plate in the 35R as per sonnax. So far the consensus is that the wave plate needs to be there.
Ive played with almost all the settings in HPT with no luck. Well I should say, I don't have the bind at first, then the trans "adapts" to a tie-up. Also, seems it binds the worst after it goes into discreet shifting and line pressure clamps around 84 PSI.
I can't believe there isnt a table/setting that could help the TCM adapt. Only thing left is the Output Torque Shift Factor, ive halved that table with no noticeable difference, I also don't fully understand how to relate the oncoming shift pressure and offset pressures over elapsed shift time, to that table. Im not paying much attention to the other shifts being it is all put back to stock for testing.
Eric
