Hello,
Looking for some help regarding an OBS LS swapped vehicle.
5.3, cnc 241's, BD LSA blower with cathedral port adaptors, LSA 3 bar GM map, BD supplied 800cc injectors could be FID (waiting for owner to supply the data from BD) Long tube headers, 3" out the back, return fuel system with E85 ability and boost referenced FPR, FiTech 92mm DBC tbody, custom grind cam, built 4l80e, single disc convertor 2800ish stall, 3.42's, 29" rear tire. P01 pcm with 2002 tahoe FF 2 bar OS
In the scanner:
The LSA map scaling is correct in the editor but, shows 0KPA koeo. I did verify it is reading by adding the MAP sae in the channels. It shows 94 KPA koeo. The two channels tracked together once the engine was running.
02 readiness/CL-normal. The system will not go into closed loop until, the truck is driven a couple miles or i rev the engine in P/N. It will go into CL and stay in closed loop once active other than OL/accel. I do not believe this is result of bad O2's as they do work. The cylinder charge temp table was disabled when I got the truck. IAT in the blower. I enabled the table and biased it closer to the IAT but allowing the ECT to partake in the festivities. MY thoughts were... this would allow CL to engage via the IAT/ECT relationship. It did not. Still needs to be driven or revved.
Gear status/PRNDL status. Koeo, scanner shows gear 2. Running moves to gear 1 in idle. Does show the transmission shifted through all the gears. PRNDL shows D4. Truck will not show the gear selector is in P/N.
Issues i am having.
Unable to get a P/N engine rev return to idle. I have added air and removed air. Added delay and removed delay. Added decay and removed decay in the throttle follower tables. I have adjust both P/N and Gear tables. I do not believe the P/N delay or decay matter since the truck shows it is always in gear. I did have follower working somewhat decent. Went for a drive and had lots of idle bounce or surge. Follower and cracker were in together. Eventually today I zeroed cracker 400-1600 rpm, 0-12mph. Added some follower air 3-13.5% tps. Idle kind of hangs but it wont come down buttery smooth.
Does the PCM seeing it in gear all the time affect the ability to adjust return to idle in P/N? I tried to adjust only the Gear 0mph column with no real luck.
I noticed the fuel psi was about 61. The editor file shows 102lb in the injector table. I tried to set base PSI to 58. Removed vac reference line, gauge moved a little but does not pull down below 61 under vacuum. Maybe the gauge or the FPR is bad. It is on my concerns list to address.
The truck came over dyno tuned. Had a ton of lean areas under part throttle conditions. It was pretty lean in lock up in a sections of the map where no timing had been inputted. Stalled out. 1200-1600 rpm range in lockup climbs into 85-105+kpa range. At the time of incident PE engagement was turned up. Found this gem while looking for somewhere to pull over. The owner commented on the WOT areas being "great" I have not put the wideband on the truck yet. I was working on the part throttle stuff. The fact it drives on the upper NA entering boost range a lot ill need to get better data there.
The main concern for now is the return to idle. It came for some ac wiring into the LS pcm and now I want to throw some dynamite in the cab.
Any help or links is appreciated. I try to scour the web before asking.
Attachment 162785Attachment 162786
