Just curious when there will be if there will be an update for options to tune the tranny?
This would be a nice feature to have and give HP a HUGE leg up on the competition. All of the other companies require you to remove the TCM (which is inside the pan) and send it out to be re-programmed.
My car made good power over eurocharged tune it also feels better and smoother my only complaint is thentranny doesn't shift hard like it did with the eurocharged v6 tune. My car with the v6 made 447 403 on ec dyno but on my buddies dyno diff day so diff air temps and all it made 437 410. After the custom tune it made 452 425. I'm extremely happy with the drivability just curious if there is an update for the tranny in the works thanks. Mods are afe filters and row airbox that's it
I have basically the same setup but with secondary cats deleted as well. I like my tune better than the EC tune for the same reasons. Unless you had EC pull your TCM (which even if you did that part would stay), their tune doesnt adjust the Trans at all. I have found tho that if your MAF trims are off, which they are if you have ROW boxes and didnt adjust for them, that will actually effect the shifting a lot.
You could also do a trans adaptation relearn and see if that makes it feel normal again.
Trans shift normal and fine it's just slower and less aggressive on all shifts compared to the ec v6 tune. It does aggressive shifts like 2 outta ten unlike before it was always hard quicker shifting just curious if we can get the trans to shift like it did before with the ec v6 tune
Car did 11.83 at 118. This past weekend but having same issue as another on the forum with not getting 100 percent throttle when pedal is pushed to the floor. It jumps to say 70 and gradually goes up as the rpm goes up to redline. I'd like help to sort this out before headers go on and I hit the track agian to do a mid low 11 pass. Still impressed with my time and this tuning program my buddy has headers and had ms109 and he could only do a 11.66 but trapped 125 ec v6 tune. Any help is appreciated thanks
Maybe a sprint booster ?
I also think it would be great to have trans support for this platform. I'd love to be able to see what my '12 C63 is doing.
I do TCU tuning for the 722.9 7G , but the orifices inside the valve body are a little restrictive to hold proper clutch pack pressures, this is why many people are using aftermarket solutions. In my opinion TCU tuning is something you want to pay once for so having all together at once makes sense, tuning for these are harder to find because the module is part of the valve body. but if you want message me i have many solutions.
http://vagaddict.com/tuned.mp4
Sharmz, can you do TCU tuning for the MCT tranny? Where are you based?
If not Sharmz, does anybody know where I can get a TCU tune performed on my unit? I want the SL63 tune applied to mine.
I can do please contact me via website or anytime at 226 476 6010
Are you able to do it with either a tactrix or mygenius device Sharmz? Or it has to be mailed in? I have a Kess as well.
there are a couple options, dependent on your controller, usually i ship out a tuned controller, then take a return on OEM controller, works smoothest for most guys, most of tuning dealers send reads from transdata for benz TCU's, mygenius might work aswel
Hi
I believe this is now available and line pressure can be adjusted. Has anyone tried this out?
Not that I can see. I even downloaded the latest Beta, there is nothing trans related in my file available
Would be great adding support to mercedes 722.6 and 722.9 mercedes.Been tuning this ecu's since 2014 and emulating 722.6 with very nice results.If any one needs any help just PM me.
Is tcu tuning availber for mercedes yet? new customer here
I could provide TCU Tune for 7G or 9G Transmissions using only Tactrix or any J2534 interface
It works perfectly with stock Transmission or upgraded clutch pack.
[Tune is made customly according to the car setup]
outlaw; I only have a knockoff Tactrix, will that cut it? If not, a knockoff you suggest, or do I need the real one?
Once that is in order, what all is involved? I assume you remote in and do your thing? Or do I pull the oem tune and send it to you to edit? The latter would be sweet if I wanted to sell it or try more than one tune.
My knockoff:
Attachment 148101
Attachment 148102
Attachment 148103
