Recently HPT added oil pressure control tables to VCM editor.
They got the Engine Torque Enable and disable correct
[ECM] 28332 and [ECM] 28333
However, their implementation of the High,Low tables is incorrect.
[ECM] 26410
[ECM] 26411
It is offset by half a row.
Attachment 159877
HPT does not yet have the Minimum oil pressure Threshold table defined
They have enough for you to confidently use trq based controls to switch the oil pump into high mode.
However, until they add the table, they do not have the table to switch the oil pump into high mode based on engine rpm and temperature.
Note to HPT: I am happy to help you help the community by getting these tables defined correctly.
Please feel free to reach out and we can discuss.
