2 Attachment(s)
e38 idle and off idle is kicking my a**
edit: be sure to read post two as i have an update
first ill give the issue, then the details or the setup, and last ill be smart and post my last log and tune file to skip being told to post it up.
As i depress the throttle slowly the motor will drop in RPM in park, in gear it will stall. If i dont baby it and push it quicker but still on the conservative side it will rev just fine so its ONLY a light throttle stall/stumble when going from 0% to say 5% accelerator pedal position. I was having the issue in park also but managed to eliminate it by increasing the airflow minimum table. Still has a slight surge when coming back to idle but not bad enought to push through the converter. I have referenced LS7 and the GM crate 525 LS3 tables and I'm well above them both now. Startup I have dialed and it lights off immediately.
If it was a Gen3 setup id be good i believe, this is my first Gen4 with a cam swap so I'm still learning the specific tables and getting frustrated
Software/electrical
E38(2007)
2 Bar OS strictly to get lower fan temperature settings
LS3 Map sensor
LS3/LS7 MAF
corvette Throttle Pedal
LS2 throttle body from 2007 Vette
O2 sensors 4" after exhaust manfiolds
Mechanical
LY6 6.0 stock shortblock and heads
cam specs 225/236 at 50 thou 110 lobe 525/525 on lift
LS2 intake manifold
12569113 LS2 injectors from 2007 Vette
2006 GTO fuel tank/pump non return fuel system
TR5 plugs gapped at .045 if i remember correctly
160* thermostat
4" air intake piping
Attachment 122401
Attachment 122402
