Could there be a reason of why MPVI3 cant read my Ford PIU?
See image.
Attachment 139449
See image.
Attachment 139449
Have you re synced your interface? It will check for updates and add as needed.
I had to do it so my MPVI2 could read my 2020 Explorer.Attachment 139511
Is there anything in the drop down box to select next to hardware?
I have re synch already, but still no luck
Yes, there are a bunch of options. not sure which to pick
Attachment 139528
Attachment 139529
Attachment 139530
The only one that seems that It wants to read is the one that says ESYS 2048K FORD, I dont let it finish and I abort the read, I not sure if that would brick my ECU.
ESYS is correct, you wont brick anything by reading
Newer MAP based Cyclones runs on TC-1791
It reads the file and saves it but cant open it. Following messages pop up right after. Already sent the VCM Suit log file to support.
Attachment 139561
Attachment 139562
Attachment 139563
Got it to work by using the VCM suite BETA
