3 Attachment(s)
Focus ST - Desired Torque Drops
Hey everyone. I've got something interesting going on with my Focus ST. I have the Driver Demand tables set up to 350 lb-ft at 100% Accelerator Pedal. At right about 3300-3400 RPM, Desired Brake Torque and ETC Desired Torque both drop from 350 to 284 lb-ft and scheduled and indicated torque both drop causing Desired Load to drop. I have been searching for a solution to this problem and so far the only thing "around" it I've seen is to hack the engine torque/torque inverse tables to keep Desired Load from dropping. Even with the hacked tables, Desired Torque still drops. I have posted a log of without the torque changes and with the torque changes. I know the log shows the throttle closing but that was due to hitting a load limiter which I later moved up. Any insight into this would be great. Thank you.
Attachment 66227
Attachment 66228
Attachment 66229
