4l60E TCC slip problems, is there a way to tune it out
2003 Yukon Denali 6.0 with 4L65e, built with Beast sunshell, shift kit, alto frictions, Trailblazer converter. 3rd and 4th do not slip but the TCC slips once my tranny oil gets to the 170 degree range. Thats not hot by any means, but it is consistent. Under a partial load the TCC slips when cruising up a hill or under throttle, which makes the temp rise even more. TCC slip is 90 min 100max and I tried bumping up the EPC by turning the milliamps down after 150degree trans temps. Even if I lock it manually with diagnostics in scanner it still slips under a load. I know its a smaller converter but at some point trailblazers had to pull a load as heavy as my Denali is unloaded. This has been going on for about a year and surfaced about 4k after rebuild/reman converter install. Any ideas?
