2020 gmc whipple lme heads and cam issues
So this thing has that new network and see hptuners has a system to provide adjustments. Question is can you disable the network sort of how we do maf priority and tune maf more so or do you have to use this system to make one of these work with this many mods?
It wont idle on its own it stalls and it keeps getting start stop fault codes which is weird. If he holds the throttle it trys to run with a lot of timing but soon as you lift its like a switch and turns off even though its got plenty of tps and timing. Not like it peters out but more like a switch.
This thing they took out all the electronics for dod so I have had to turn off a ton of fault codes on it.
I guess the main question is am I having a start stop problem or its the network settings that make it not want to run? Before dropped 50 bucks on tokens wanted to see if someone found can just set it up to run more maf priority or not.
