Hi gays
I change the stock injector to big one which is Bosch 630 cc?. How can I change the injectors current???? Because I have problem with it.
Hi gays
all I see is this...
I'm assuming we change the injector slope and maybe the voltage offset?
where do we find those parameters?
Attachment 117451
I'm still wondering this too, ID is supposed to get the parameters up on their site for their injectors, but so far, they haven't I don't think.
They have been on there for a while, here is the link but instructions are for DJ. Numbers don't match up for HPT though unfortunately. DJ sais airmass were HPT states Fuel mass on the inj scaling table.
http://injectordynamics.com/utv/
Edit: Guess you could use DJ's scaling and do a % difference to get you close.
HPT Fuel inj difference 2018 vs 2020
.753867998369023
= % .246132001630977
Dynojet Fuel inj difference 2018 vs 2020
0.7538702937647365
=% .2461297062352635
Dynojet scaling is wrong. Injector Dynamics values were built around the incorrect scaling.
I've spoken to ID, and they have an updated calculator coming out that outputs the correct values.
I was just stating you could use the stock inj values in the DJ software and then grab the values off ID site for whatever your using if it's their 1050's ect. Then do a percent difference between the two and apply that percent diff to HPT's inj number to get close. I used the the two different inj sizes between the 17-19 x3's vs the 20+ from both DJ and HPT to show that it is extremely close using the percent diff to compare to get you a number.
DJ injector scaling 18-19 is 0.119177. The 17's were a little different, they had the same injector but lower fuel pressure.
I grabbed the info off Id site for the 1050's the new scaling number for DJ would be 0.0370, you would do a percent diff with these and apply that to the HPT slope could get you close may not be perfect.
HPT's calls there Inj slope, 18-19 is 0.76273333
I did just notice the voltage correction is different between the two platforms also, DJ calls theirs latency and HPT's calls theirs voltage offset. Not sure but you may be able to do the same with the voltage doing a percent diff, hard to say might just be worth waiting until Id updates their site to include HPT's way of doing the inj input.
I'm still using DJ's stuff with ID1050's and E85, i'm only here to see if it's worth switching or if I see something I just can't do without. I do have a MPVI2 and picked up the adapter cable to check out the options in the scanner and editor.
18-19 what? Commander, Defender, Maverick, X3?
There's a calculator out now, should make all inj parameters come out right hopefully. I'll be trying it out over the next few days.
Hopefully it's ok to post this on here:
https://www.wolframcloud.com/obj/pau...tor%20-%20Beta
I made one called "afr error"
Attachment 118174
I have a SeaDoo 1630..
O2 sensor is in the exhaust mahifold, so it's getting all 3 cylinders.
VE table covers all cylinders.
