Ethanol Content Channel
Hi guys,
I would like to see the % of ethanol in the gas I get from my favorite stations - up to 10% ethanol *. I do not have any E85 stations near by unless I drive a long ways.. If I enable flex fuel I will get the channel but do I need to have all of the ethanol parameters correct? I'm thinking yes.
The Flex Fuel Ethanol % vs. AFR is populated correctly. I also have most of the FFV tables populated.
Stoich AFR Init, what should this be? Can someone running E85 share a screenshot of the Flex Fuel main page please? Do I need to run a different fuel ratio as well in Closed Loop Lambda at WOT (Flex Fuel) ?
wouldn't you need an ethanol content sensor to get that reading?
I think the Ford strategy uses the O2 sensors and some logic to estimate this so no sensor is needed. But I've never tried using it myself.
There’s a thread in here somewhere that lists all the parameters to get flex fuel setup. Think they copied the flex fuel settings in the truck map
Find a F150 cal that has flex fuel enabled and copy over all the flex fuel data. That's what i used to start out.
If you enabled the logic you need to repoll the PIDs for it to appear
Repoll and it’s fixes. It
And then depending how aggressive u tune E85 u are gonna. Run into fuel insufficient on 18 and up
