2 Attachment(s)
GT350 TB is not opening 100% on my 2017 GT
Hello,
i changed to GT350 TB and CAI on my 2017 GT.
The TB is not opening to 100% (see log below). Have I forgotten something ?
I adjusted following parameters:
Engine - Airflow - General - MAF Calibration - MAF Temp Compensation - FRPP2_GT350_TB_and_CAI_GT350 copied (axis + value)
Engine - Airflow - General - MAF Calibration - MAF Airflow vs. Period - FRPP2_GT350_TB_and_CAI_GT350 copied (axis + value)
Engine - Airflow - Electronic Throttle - TPS Configuration - TPS Config - FRPP2_GT350_TB_and_CAI_GT350 copied (value)
Engine - Airflow - Electronic Throttle - TPS Configuration - Sensor Slopes - FRPP2_GT350_TB_and_CAI_GT350 copied (value)
Engine - Airflow - Electronic Throttle - Limits - Max Throttle Angle vs. RPM - FRPP2_GT350_TB_and_CAI_GT350 copied (value)
Engine - Airflow - Electronic Throttle - Limits - Throttle Angle Max - 85,125 to 92,0
Engine - Airflow - Electronic Throttle - Throttle Body Model - Predicted Throttle Angle - FRPP2_GT350_TB_and_CAI_GT350 copied (value)
Engine - Airflow - Electronic Throttle - Throttle Body Model - Effective Area - FRPP2_GT350_TB_and_CAI_GT350 copied (value)
Engine - Airflow - Electronic Throttle - Limits - Max Angale - 90,0 to 92,0
Engine - Airflow - Electronic Throttle - TPC Configuration - Current Max Clip - 2,5A to 2,75A
Engine - Airflow - Electronic Throttle - TPC Configuration - Gearlash Tolerance - 0,05 to 0,06
Engine - Airflow - Electronic Throttle - TPC Configuration - Gear Ratio - 20,2 to 18,9
Engine - Airflow - Electronic Throttle - ETC Angle Filtering - ETC PR Filtering - FRPP2_GT350_TB_and_CAI_GT350 copied (axis + value)
I picked the values from a FRPP2 file from the forum here. Attachment 109882
Log:
Attachment 109883
