After the latest update of the vcm reader
I can't read the aircharge in jeep dodge cars
The software can't find the aircharge parameter when I connect it to the cars
I used to read it before and has no issue
Using beta version
Using beta version
Beta 4.9.1012.0 ?
I also found this issue too. Accelerator pedal voltage parameter didn't work either. It seems like they may have renamed/restructured the PIDs which is an absolute pain when you have spent quite a while setting up your logging layout.
Any luck?
The ability to disable o2 sensors is also missing from the Beta Editor. I have a feeling this is related to the current emissions uproar.
I can also confirm that Aircharge is missing from the Beta Scanner. I have to use the current stable version.
use cylinder airmass instead of aircharge
we need a fix!
Try downloading latest Beta. I opened a ticket as I had a 2021 Redeye and going to older version would not work.
Latest beta has fix for aircharge.
