Seems all LFXs from the factory have a very slow opening for the throttle body to get to 100% open. Has a way been found around this yet. There is a lot of low end power just waiting to be unleashed.
Here are your main tables you will need to adjust.
Attachment 65520
Engine>Fuel>Power Enrich>Power Enrichment>PE Enable>Enable Torque (stock value is normally 95% , i personally set to 80% across table)
Attachment 65521
Engine>Fuel>Power Enrich>Power Enrichment>PE Throttle/Pedal>Enable Pedal (stock value is normally tapered from 90% down to 45% , i personally set to 65% across table)
Attachment 65522
Engine>Fuel>Power Enrich>Power Enrichment>PE Delay>RPM (stock value is normally 6,200 , i personally set to 2,000)
Attachment 65523
Engine>Fuel>Power Enrich>Power Enrichment>PE Delay>Torque % (stock value is normally 100% , i personally set to 10%)
Attachment 65524
Engine>Torque Management>General>Torque Limit vs RPM>Max Torque>Peak Torque (stock's max value is 328 , i personally set to 500 across the entire table)
Attachment 65525
Engine>Torque Management>General>Torque Limit vs RPM>Max Torque>Tip in Enable (i personally set to 0 across the entire table)
Attachment 65526
Engine>Torque Management>Engine>Driver Demand>MAP A - Normal (i personally set the 100% row to 350, 80% to 295, 74% to 230 and then do some slight smoothing of the table below that)
Attachment 65527
Engine>Torque Management>Engine>Driver Demand>MAP B - Winter/4wd (copy MAP A table after adjustments and then paste to MAP B)
Attachment 65528
Engine>Torque Management>Engine>Driver Demand>MAP C - Sport/Tow/Eco (also copy MAP A table after adjustment and then paste to MAP C)
Those are just the basic tables that I use to get max throttle open as quick as possible.
WOW, thanks I'll have to get some help to all of this but again THANKS!!!!
is the driver demand table the one that controls the throttle? what does this change of 100% - 350 value does?
Oh so we cannot open the TB 100%, i know i tuned mine and now i do have more throttle response, but i don't remember which table was, i'm going today to the dyno, last dyno was 270whp, improved baseband hp from 223 to 243hp, mods are injen long intake, cherrybomb exhaust, muffler delete and 3.91 gears
Necessary parameters for the instant opening 100 percent throttle are not located in the main program. This is located in the coprocessor and can not be tune using the VCM Suite. In the main calibrations also there are several the torque limiting that are missing in the VCM Suite. For example the torque limit depending on the vehicle speed and more.
Alexdiag is there a way to send out my PCM and have the parameters in the coprocessor reset?? I know some the new 6th Gen Camaro TCM are being pulled and sent out to unlock.
Just did your recipe on a 2017 Acadia limited 3.6l and it really helped turn up the wick! Thank you!
You outa tune it to an 87mm tb, lol, holy moly, thats a 6 cylinder doing that
