Hey
Does the period control feature can directly control the stoichiometric AFR? or are is a another option ?
I want to change stoichiometric to 15.5 AFR to get better MPG.
Nissan Y62 2016
Thank in advance
Hey
Nissan Y62 2016
Thank in advance
The MAF should only be altered if the MAF or intake is different to stock. The compensation Fuel tables allow for the mixture to be dialled in, the MAF id calibrated on the Bench to be correct, adjusting the MAF gives a false airflow reading which in turn makes the torque calculation incorrect.
I would adjust the AFR conversion and the Equilibrium point by the same amount if you wish to run leaner in closed loop, I have not tried but it should work. You may also need to adjust the rear 02 non-activation.
[QUOTE=4wheelinls1;674655]The MAF should only be altered if the MAF or intake is different to stock.
Yes that's right.
