At first, wow :D long answer!
Quote:
Makeclick, this reply is mainly for you, but since we're both taking stabs in the dark here I hope others will chime in.
So you're saying if you bump the Normalized Torque xx%, then bump whatever the % torque is on the table by the same xx%, it'll work?
Quote:
Yes it will :) If you multiply "torque to load table" with the same multiplier, but you have to multiply "engine load" rows also, because you will need more air to you new 0-100 scaling (NT)
Quote:
My understanding is we can't see all the charts, only the most important ones. So if we missed one then it's instant limp mode?
Quote:
Maybe... that is why you need change all torque tables and monitorin tables (only "engine load rows") and then it could be worth of nothing :banghead:
Quote:
Also, do we really need to exceed the Normalized? I know mine is 885 for an eng that oem makes 450 and certainly can't make 885. On the other hand, I do know that I can raise the Driver Demand past 885 and it responds, so is it referencing Normalized? If so, then I guess 885 is just a reference #, not a limit. Meaning I can ask 110% and it gives it? Not that I'm making >885, just that I plug in >885 and power does increase, so from a numbers perspective it's working.
Quote:
Like description Normalize is scale for 0-100% of torqure. If you set it (sorry i need to use NewtonMeters) 450Nm->550Nm you can calculate new scale with excel. Example 50% torque is OEM 450*0,5=225Nm -> 550*0,5=275Nm SO, when you change the NT it will scale everything up and can mess everything up :D if tarbles/charts will use 0-100% of torque.
Quote:
Trust me, I'm guessing here because this is all super confusing. I just keep pushing buttons until something happens, and I can assure you I've had to reload the ECU on the side of the road because the eng shut down more times than I can count.
Quote:
Not meany, but been there :D
Quote:
You said if you increase the Optimum Torque too much and the Torque to load not enough, you get a fail, which I know all too well. But I raised my Optimum just a wee bit and raised the Tq to Load up a lot. It seems to me that simply messing with Optimum at all is risky and its best left alone?
Based on the values in the Optimum chart I wonder if this is volumetric efficiency? Or is it just random values used to mathematically end up where you want in the end? Meaning maybe they could be ten times that as long as other valued elsewhere brought the final value back to where it should be? To be honest I don't understand why Optimum exists at all.
Quote:
Easy way is to only raise torque to load map, but the engine calculated torque is lower than it is in real world :/. I think the optimum torque is like theoretical maximum torque, but then there is many many different tables which will try to lower it down.. like spark and lambda efficiency. I am with you! I think this optimum torque is one piece of....
Quote:
Then there's what outlaw said, which is the opposite of the picture:
"Throttle position (Driver Demand) -> Optimum Torque -> Optimum Torque (monitor) -> look for the percentage on Torque to load map -> ECU asks for the load (which calculates the boost needed)"
This makes more sense than the picture and it's what I've been going on, but still don't see why Optimum needs to exist. Surely it has some other function in life?
Quote:
Yes, this is good info and it seems to fallow that, but still m133 can go 420-440~hp and then there is mystical wall :)
Quote:
Then I also wonder about the % for the rows. Optimum goes to 180% but the values are <80. Ok, so if I ask for 180% torque that ends up as a value of 75 in the chart. outlaw said that goes to Optimum Monitored but I don't think it goes into Monitored, but maybe it's comparing or double checking? No clue to be honest.
Then if that 75 goes into Torque to Load, 76 = ~180. Ok, but then I wonder because 180 is what I asked for originally, which is why I don't see the point to the Optimum charts.
I also wonder because increasing Torque to Load didn't do much for me until I increased Max Torque Driver Input (Torque Management/General). So really I had to increase both Torque to Load and Max Torque Driver Input.
Quote:
You mean "engine load" row in optimum torque? yes, so that is engine load, we live in ~1 bar/100kPa -> 0,145038 psi, so it is absolute 1,8bar/180kPa -> 26,106795 psi.... Yep :D it will be easier to think metric like Germans/MB do. You asking engine load and it will end up in the chart of "optimum scaled 75% of engine torque" (450*0,75=337,5Nm). Yep, that is a mess.
Quote:
So Max Desired Load is apparently a limiter?
Quote:
Yes, you have to change that.
Quote:
Imo there should be one chart; gas pedal position = torque out. Done. Maybe once you remove all the limiters and max out some bs crap you can get to that point.
Speaking of: I see under Airflow/General there is Manual Control for Desired Load... It appears you can set throttle position to directly = Desired Load. Anyone try that? Would this bypass the Torque to Load? Bypass Desired Load? I'll probably just have to try it and see huh?
Quote:
I did, but my car was awful to run with it and i lost my OEM "fanfars" pop and bangs. Same will happen if i set Wastegate to manual control.
Quote:
There is also a manual control via throttle position for the turbo, but seems to me manual based on throttle position would not work out. But as-is my wastegates and boost are all over the place so who knows, maybe it's better than what I have? What is yours? You said you bumped it from 1.8 to 2.4, but when you say that do you mean peak or average? My peak and average are very different, like peak might be 22psig and avg may be ~14? So I guess that's peak of 2.5bar, low of ~1.5 and avg of 2bar? All within 2 seconds btw and usually never the same. Like the next time I floor it might peak at 16 (2.1bar). It may peak in a split second and very quickly drop fast, or it might start low and slowly increase. It may spike up when it shifts, it may drop. Frustrating... So when they say the oem boost for mine is 13psi, I don't know if it's supposed to be 13 across the rpms, or is it all over the place like mine?
Quote:
22psi is 151,6kPa or 1,516 bar. Is it boost or absolute? Do you log you Wastegate? You should. Do it dance or is it more solid? How your TPS acting and commanded TPS?
I was talking the boost not absolute pressure. The absolute pressure is now 360kPa ->52,2psi :rolleyes: 5500rpm-6500rpm. Stock is 280kPa in A45 amg, so quite high. Now I hit the wall.. Fuel pump is barely keeping up :D. this is 3rd gear, but 4 gear it is lower and i don't know why.. It hit some engine temp limiter, because lambda goes 0.75 and load is 320kPa or 340kPa. Still fast but odd
