LSA Injector Swap into LS3
I am about to drop in some LSA injectors into my N/A LS3 due to a flex fuel conversion and I have a few questions.
1) Are these all the tables I need to copy over? I am pulling the data from a CTS-V file from the repository.
2) And then I am not sure about the Min Rail Pressure. Normally my fuel pressure is 400 kPA (58 PSI)...so I am not sure if I need to change this? Is this needed if the car had a blower?
[ECM] 12307 - Injector Flow Rate vs. Pressure Delta
[ECM] 12319 - Injector Flow Rate Modifier vs. IAT
[ECM] 33390 - Injector Flow Mult vs. MAP
[ECM] 33392 - Injector Flow Mult vs. Fuel Flow
[ECM] 12315 - Minimum Injector Pulsewidth
[ECM] 13541 - Minimum Rail Pressure (LS3 was 300 kPa, LSA is 150 kPa)
[ECM] 13542 - Maximum Rail Pressure (LS3 and LSA are both 600 kPa)
[ECM] 12303 - Injector Offset vs. Injector Temp
[ECM] 12308 - Injector Offset vs. Pressure Delta vs. IGNV
[ECM] 12314 - Short Pulse Adder
[ECM] 13341 - Makeup Pulse Minimum
