2018 Mustang GT T56 Magnum Swap
I'm having an issue after swapping a T56 Magnum transmission in a 2018 Mustang GT. The issue is only in third gear at part throttle the spark source changes to "Torque Control" and timing drops drastically (all other gears seem fine). I've updated the tune with the correct gear ratios for the T56 and well as made sure the min /max ratios had room either side of the correct ratio. This is on a stock whipple tune with the only other adjustments being for ID1050x and return fuel system. Any ideas or is the software missing something?
