Jay do you want me to log before flashing the new inverse tables or after?
I have updated the tune file on the laptop but haven't flashed it yet so was wondering. Did the numbers look okay to you?
Preferably with the matching tables, histo that matches the fuel mass that's in your tune.
Tables are both set in editor and scanner so I am ready for logs when I get off in 2 hours.
One thing I noticed with looking at my last log. My manifold pressure showed 222 KPA at full throttle in the middle to upper powerband. I multiplied that number by .145 to convert to PSI, and then subtracted 1 bar (14.7) and ended up with 17.49 PSI. I was told this pulley is good for 19 - 21 psi by HHP. Am I doing the math wrong possibly? I know the stock boost sensor wont read beyond 17, but I am reading this from the MAP sensor.
Well I doubt you're up so I'm going to lose another night here. I don't know how to proceed. See the attached screenshot. This whole time I was focusing on getting the two blue columns in order and just realized right before I flashed that the red columns still aren't matching. I'm assuming you want me to adjust those in line with each other correct? Can I just copy the values, paste them into notepad, and then paste them over one by one? I am ready to do the logs still, if you happen to reply.
The data listed from FIC is in milliseconds for InjPW and milligrams for Fuel Mass.
To input the data easier change your Fuel Mass to mg. Then all you have to do is copy and past from their data into HPT
Thats how I did it, then changed fuel mass back to grams just because that's what I'm used to looking at.
This is what your data should look like. Attachment 75345
Change your Fuel Mass to mg like this
Attachment 75347
Then they will look like this
Attachment 75348
Then open the excel file from FIC and copy the select and copy the InjPW data
Attachment 75349
Then select the InjPW row in your tune and paste it
Attachment 75350
Copy the fuel Mass data from the excel sheet, click on the Fuel Mass on the left side of the table, select it and paste
Attachment 75351
sweet, you replied a few seconds before i did. make sure you are logging fuel mass in the same units as its setup in the tune, g or mg or days, which ever you prefer, haha
Just checked every single log I have and I find it suspicious that every pull only reads to EXACTLY 222 KPA. Not 222.1, not 223, exactly 222.0 max every time. Is there some limit that needs to be removed so that it can read all the boost? Stock MAP sensor.
This is what I'm referencing.
Both are higher than 222 so you would think it can read higher. This is odd.
All bypass valve values are stock btw
Raise the Map 2 value to 249 and see if that changes anything. Also try logging the other MAP sensors. It has 4 IIRC
