Originally Posted by
dr.mike
A wideband can be field-calibrated, in a way that a MAF can not ( Unless you have a 2000CFM flow bench ). You can use the 20.8% of free Oxygen in the atmosphere as a calibration point. Or, more correctly, the partial pressure of Oxygen, at whatever altitude you are at.
As long as you are using digital data transfer from the WB to the logger ( OBDII/CAN or serial ), if your WB displays the correct Oxygen% in "free-air" for your altitude, You should be good to go.
This is different from the common "free-air calibration", where you just force the WB to read 20.8% at whatever the pressure actually is.
A WB actually, does not measure AFR, lambda, or, even Oxygen% . It measures the partial pressure of Oxygen. So, it is affected by altitude, barometric pressure, temperature, and humidity; mostly, in that order. You can get really close with altitude/elevation, alone.
With a good calibration, a WB should read the following Oxygen%, with the sensor in open atmosphere ( "free-air" ), at a given altitude, plus or minus about 2% of the reading, to account for barometric pressure, temperature, humidity, and 1% variance of the sensor:
ELEVATION O2% reading +/- 0.2%
0'MSL 20.70%
500'MSL 20.56%
1000'MSL 20.42%
1500'MSL 20.28%
2000'MSL 20.14%
2500'MSL 20.00%
3000'MSL 19.86%
3500'MSL 19.72%
4000'MSL 19.58%
4500'MSL 19.44%
5000'MSL 19.30%
5500'MSL 19.16%
6000'MSL 19.02%
6500'MSL 18.88%
7000'MSL 18.74%
7500'MSL 18.60%
8000'MSL 18.46%
8500'MSL 18.32%
9000'MSL 18.18%
9500'MSL 18.04%
10000'MSL 17.90%
Assuming that you have a WB that can display O2% and DOES NOT REQUIRE FREE-AIR CALIBRATION ( which ruins the entire purpose, here ), if you see a reading that lines up with the above table, your O2 sensor is, almost, dead on. So, at least the WB, itself, knows the actual O2%, lambda, AFR, etc.
If you have digital data transfer from the WB to the logger ( either CANBus or serial ), you are good to go. If you are using analog voltage for data, there is some work to do, before it can be trusted. Here, ground offset issues are, usually, the source of errors.
