2 Attachment(s)
2010 Camaro TCC random unlock
Hey guys. I installed an SS3 VVT Cam from a BTR stage 2 3 bolt, and have had problems with my shift points and lockup ever since. I have tried to hunt the problem. I am seeing low misfire counts.... in the 6-8 total range while driving, and the vehicle will not lock based on set points on a consistent basis. Once it does lock, it is random if TCC stays engaged. Converter is a 3200 278mm Circle D. Attached is the tune and a log of where the release happens. Shows up at time hack 17.891. Once unlocked, the vehicle will not lock until I cycle the key. I can see no significant change in any parameter that would drive unlock. I have thought about flashing my stock tune in via a write entire, and rebuilding the tune to rule out possible corruption. Any ideas, or additional info I could provide?
