Originally Posted by
Prop Job
SOI = Start of injection.
I was curious if that was actually the #2 cyl or #2 in the firing order.
Why does that cyl need special treatment?
Would I be taking to much of a risk if I zero the table out?
Should I still keep stock knock sensor settings with my setup (2300, 70 mm pulley, bolt on's, pump 93) or desensitize?
I also made another discovery yesterday, the after write idle issue I was experiencing was due to the Vitesse Throttle Controller. Removed it and now it acts normal after writing.
I'll be putting it on the dyno next Tue.
