Tuning AFR part throttle help
hey guys, just a quick question about tuning to your AFR both MAF and VE
it seams no matter how much I try my idle and low throttle never get corrected. Most of the graph I can get close to +/-5 but my idle is always off. I?m tuning based off my wideband with my fuel trims turned off. When i turn the trims back on they get me close but than my AFR jumps around and my fuel trims are never steady. Also if I try tuning off my fuel trims and not my wideband I have the same issue. I am running a big cam and switched to a LS3 MAF. My curves are good and my WOT is almost perfect for my commanded AFR
my question is would the size of my camshaft throw off my readings at idle and low throttle on both MAF and VE tuning?
Anything I can do to dial in better?
