any tips or help doing a l83 2016 swap and injectors wont open
The VATS should be under the OS tab, you disable it and then write entire.
Newby here with a chicken or egg riddle. 11 Camaro SS that I recently acquired, complete rebuild trying to do a first time start up with a stock tune installed in a new E38 PCM. BCM is original. With the VATS and Starter diag. patches Disabled I get crank with spark but no injector pulse (voltage at injector). 2 DTC codes are Crank relearn and P0633 Immobilizer key. I "think" guess that I have 2 different relearns fighting each other. My research says P0633 goes away at start. PCM wont give pulse because of crank? Any help or tips would be appreciated for the Rookie.
