Vortec BBC 24x swap base file request
I have a 99 Suburban with the 454 that I am going to be doing a 0411 swap on and will be changing the reluctor wheel to the L21 24x one. I also intend to run coil near plug ignition. The motor will be stock but freshened up with new rings and bearings.
I was hoping to find the l21 base tune to work with and segment swap the transmission, or at the least pull data from the base tune to input into another tune. I already have a licensed 02 silverado tune, I think that is a decent starting point and it won't cost any additional credits, although it isn't the end of the world to buy more.
Is there any real advantage to running the blue and green PCM over the blue and red? I have both and the blue and green has the IAC driver.
I am trying to get this to work on the stock motor as I figure once I get the electronics worked out and everything working properly then I will be building another motor with some additional kick.
So, to paraphrase.
Does anyone have a good suggestion for a good base tune?
What are the advantages to the p59 over the p01 for a BBC?
