Any info on if i can tune my 01 Dodge trans with a Cmmins in front of it?:shrug::drivin:
Pretty much only thing you can do is add a transgo kit to it They still run of Throttle pressure cable for shift firmness and timing the Transgo kits are Great kit work good if you leave out the 1-2 accumulator spring and hog the holes out in seplaterator plate and give about 1/16th of a inch of gap on the Pressure regulator valve then they hit good in every gear.
Trannyman
