So this truck is confusing me, unlike the GM maps there is no tire change table. Do you use the VSS? Can't use the scanner like my Jeep either. Any help would be great!
If you changed tire size, you want to change the "VSS Tire Revs per"
You can lookup how many revs per mile your tire size should be. You will need to make minor adjustments to get it exact.
Changing the VSS does not correct the speedometer though. I'm not sure what the VSS does...
