Anyone got a base file to start from for a tomahawk 2.0 something to work off of having a hell of a time to get it to idle
post your current tune file and stock and a data log and ill try to help you out
i need the same for the mark 82
i can sell you a custom email tune or a base map but that camshaft require some tuning to make it run right.
here is a startup i got from a full tomahawk cam kit. this startup was based on a 2017 charger rt 5.7L. i do not know if this will help you but i hope it does. forums imo should be in place to help each other..
you guys must have some good gas there
@lilsick id say yes we got some good 93 oct fuel here.. here is a log of the tune i sent to here on the dyno. and the same car went from this stock setup to FRP full stroker kit and a widow maker cam on pump E85.
How did the car drive? That idle is pretty high.....
This is me just starting also having issues with it not shifting into 3rd
Attachment 142022
Car drive really good once its rolling the car itself when coming to a stop bucks like your riding a bull. with the new setup on ethanol and a 3200 stall converter it runs like a dream.
