Ben, if you need/have to go to a 98-up PCM, you will have to rewire the PCM harness...move pins here and there. Go to this site for your pinouts and any 1998 style PCM:Quote:
Originally Posted by big_news_1
http://home.att.net/~subzero350/
To run the -60 with it, just connect everything you normally would with the exception of the force motor and the trans speed sensor (not talking about the one at the tailshaft). Then set those values to zero, and delete the codes associated with those controls.
