e38 injector driver limitations
Hello all,
Looking for some technical information on the e38 injector driver limitations. Specifically, are they limited by resistance maximum/minimum which prevents them from running high/low resistance injectors?
Or is it an issue with current draw and the driver is limited to ~1A?
Reason for asking...I am in a pickle with trying to run 16 injectors due to fuel need for port injection AND injectors above a 6-71 supercharger in a plate design. Yes, I can run 8 larger injectors in the plate, but then there is concern for lean/rich cylinders. Yes, I could run the supercharger 'dry' but that introduces MUCH more heat and inefficiency, which is further complicated by the lack of an intercooler/brick.
My thought is to do paired injectors in parallel with added resistors so the e38 PCM 'sees' the same resistance as a single set. In doing so, what am I missing and not considering in this idea?
~Ryan
Charleston, SC
