Originally Posted by
Rockhound
I bought an 07 NGC4 pcm and swapped it into my 06 300c. It did start the car however the ecu was already dead when I received it so I could not read it at all let alone program it. However, the first time, it did start the car and let it run despite the skim mismatch. I shut the car off and tried to start it again and this time the skim prevented it from running for more than a couple of seconds.
So since the pcm is half dead already and I cannot connect to it with my programming tools, I cannot properly program the vin to see how the car will behave with the NGC4 installed. I have another one on the way here and will let you guys know if it works. It is my understanding that the 06 EGS52 TCM may not be compatible with HP Tuners, but the 07 EGS53 is. So maybe we can swap both the 07 PCM and TCM in.
I will post my results when I have them.
