06 logging ...?
Is this even possible? Right now I have to do a horrendous process of making changes in HPT then reading in EFILive and converting to CSP5 and logging. That ends up being a flash with EFILive normal tune, then a read with HPT, another flash with HPT, then a read with EFILive, then a flash with a CSP5 tune with EFILive. Only then I can log and from going through this process it seems that EFILive custom OS might overwrite some stuff. Anyone ever try this?
Why bother with HP Tuners if you have EFILive is the real question...
But yes you can log a 2006 with HP Tuners.
But seriously, you are just chasing your tail with what you are doing. Just stick with EFILive.
And yes, every time you flash with EFILive it overwrites what you flashed with HP Tuners and every time you flash with HP Tuners it overwrites what you flashed with EFILive.
I have my reasons for using HP tuners.
If it is possible then tell me how to do it? There is no extended datastream modification available in the operating system page like there is if I look at an 05 file. I am assuming that's how you enable the logging.
