1 Attachment(s)
Built 6l80 failed, help me diagnose why!
I will try to put all the useful info in here to start. The car is a 2009 G8 with a LSA blower. The car makes an estimated 650-680whp. I put approximately 14k miles on the bone stock 6l80 with 600whp and had no issues. (92k-106k) I overrevved the stock block and tweaked a rod so while the motor was being built, I built the transmission.
Parts List:
New bellhousing/pump, upgraded pump rotor, all the Sonnax upgrades
New 1-2-3-4, 3-5-r assembly, Sonnax 1-2-3-4 piston, Sonnax 4-5-6 piston kit
Sonnax billet intermediate shaft for factory clutch pack
Alto Red power-pak in 3-5-r, 4-5-6, and 2-6. Raybestos stage 1 in 1-2-3-4. No wave plate in 2-6 and 4-5-6.
Sonnax zip kit and tchm seal kit.
New GM ZL1 converter, camaro pan, ctsv filter, Hayden 11x11 cooler inline with factory radiatior.
At almost 3k miles on the built motor/transmission, I made a 3-4 and into 5th pull. Everything felt good during the pull, shifts felt fine. It shifted to 6th and was normal. I went to pull off around a turn and it locked in 4th and threw a CEL. I got it home and it was showing P0700 and P0797. Attempted to reflash the trans, didn't work. Revving in park would push the car forward (I was logging here and temps got up to 190). I lost all gears and had it towed to a local transmission shop. They pulled it apart and found every clutch pack burned up. They couldn't find any issues with the rebuild, everything was in spec and pump looks good. They believe the tchm failed and caused pressures to get screwed up and toast the clutch packs. No metal in the pan indicating torque converter failure, only clutch material.
The transmission never ran hot, it would sit in the 140-150 range. I never experienced slip and things that would indicate something was wrong. The only thing I had happen worth mentioning was at about 1500 miles, I started hearing what sounded like loose flexplate bolts or cracked flexplate at 1800 rpm only. I checked everything, could never find the source of the noise. It was only at 1800rpm, revving up or down.
I'm having a new GM 6l80 put in and I'll bring my transmission back to check closely and rebuild as a spare. But I'd like to see what the experienced guys think of my tune. It was completely self-tuned after doing a bunch of research and reading on 6l80 tuning. I just want to verify the tune wasn't the cause or part of the reason for the failure.
If you don't want to read all that, I'm looking for opinions on my tune to make sure it wasn't the reason for failure.
TIA! :)
