Tech support says hp tuners isn't compatible with the 2023 skis, wanted to ask the group. 2023 gti 130 and gtr 230. Pretty sure theyre identical to the 2020 models.
Ok, so just to confirm, 2023 gtr 230 is compatible.
For the 2023 gti 130 I need to get them the ecu. I assume thats so they can pull the base files for when you "read" your ecu.
Thanks RaraK!
RaraK69,
I just got the setup going for HPT. The 2023 GTR 230 pulls the file fine from the cloud,
But I get the unknown controllers error, which basically confirms the ecu hasnt been accessed by HPT.
Would you be able to provide the oem file for that 2023 gti 130.
All I am looking to do is transpose the variant 0 (or the more aggressive torque, ignition, and fuel, throttle blade angle, etc.) table values into the variant 1 (or really all of them) to make the ski an oem 170.
Ond the other obvious question, will I be able to write the altered cal flie to the existing ecu.
If I have to send it in, I will, just trying to avoid that if possible, but if it may help someone down the road, that would be nice too.
Thoughts?
AMartian,
I dont. Is there a way to discern with features or some physical attribute of the ski?
I'm pretty certain its the same ski from 2020 on, and its not the se, just the base.
Thank you.
