Go Pro 10 software 01.46 causing weird sensor data import issues
Something is wrong with the accelerometer import from GoPro Hero 10 . Prior versions of GoPro video seem to have more stable data updates. Prior versions of GoPro (from July) seem to update about once every 250 ~ 200ms or so. The newer GoPro software seems to yield a one-two-three-DROP pattern on the data where every fourth data value is just dropped. This causes all kinds of crazy behavior in the interpretation of the data by race render. I do not know if this is a GoPro problem or a RaceRender reading the data problem. You can see the "bouncing" result on https://www.youtube.com/watch?v=j4YPjy9ueFg where the speedometer and accelerometer look like they are bouncing. Here is the first few seconds of the same video but with Boost Sample Rate disabled https://youtu.be/tHI6s1hs_Mg
This is from a GoPro Hero 10 and the problem is encountered on software version 01.46
