'94 LT1 4L60E in a 0411PCM with 12202088 OS
Hi All,
I've got a 94LT14L60E with the 11 pin connector and no PWM TCC lockup solenoid that I want to put into my 400SBC 24x conversion project.
Other than changing all the D2903 and D2904 PWM values to 100 (or 99.6), is there anything else I have to do to get this to work?
Will this work with the stock 12202088 OS?
Will the calibration need the other pin to be present or wired into something?
I can possibly swap the harness from my 96 4L60e box and use the existing PWM TCC soldenoid from that, but are all the other solenoids and valve body gear the same or will i run into trouble?
