On the topic of distance tables, does anyone know how what parameter controls when the VCT mode enters/exits Emissions Reduction?
Also under VCT->Optimal Stability-Enable Max Load, the table is set for .13 Desired Load vs 6,500. This means Optimal Stability is only enabled @ 6,500 with a .13 load? Or does it mean if I were at 6,500 RPM and .13 Load (probably impossible) Optimal Stability is enabled... Or wait I think it might be if Desired load is 'under' .13 @ 6500 RPMs Optimal Stability is used?
Finally Desired load, is this AIR LOAD or Desired Torque?) I don't see a channel with "Desired Load"
This part confuses me! I'm trying to understand how the VCT modes are selected. Some are obvious while others are mysterious :D
Attachment 80008
