6L80E Can I use an 08 TEHCM on a 2011 Valvebody?
So I know that the -09 valve bodies are different from the 10+ ones.
And the same for the TEHCM's that get mounted to them.
Does anyone know if it's possible to use a 2008 TEHCM on a 2011 valve body in a 2011 6L80E trans getting swapped into an 08 truck?
Original trans, valve body have had better days and are being repalced with the 2011 trans, and valve body if it works.
Doing a rebuild on the 2011 donor trans and valve body before getting installed.
Thanks everyone
