Hi.. Any news about jtec and jtec+ tuning... I have the mpvi2 interface and nothing.. I think just read on gm serial and can bus... But nothing on sci and pci bus of dodge and jeep protocols... Very bad folks
I?ve made an immobilizer delete solution for a 2005 Viper SRT-10 8.3L and would need to delete some fault codes as the engine is going to be retrofitted without some emissions related sensors.
My question is that if I have read AB28F200B5B flash memory from the GEN3 pcm with a Beeprog2 programmer, am I able to modify the firmware with VCM and export it as a complete binary file and write to the flash memory so that checksums are corrected and car starts? I don?t mind if it cannot be read via diagnostics but atleast it would be great to have the PCM firmware modified. :)
Does datalogging work for JTEC STR10 ? i was able to read and open ecu rom, but not able to datalog anything at all with mpvi2 cable ...
When will we be able to turn off DTC codes for the jtec+? I have customers needing some codes turned off and they don't like the CEL light on.
I would like to help :) And I have a 2006 in the driveway. I have not ever worked on a dodge pcm though. Do they use a bootloader to read the pcm, or just J1939 stuff?
Any updates on this guys?
Any update on opening up the DTC table for the jtec ECU?
Does anyone have a log file or a basemap I can take a peek at? Would like to see how much timing ppl are running on pump and corn
Has anyone done a srt-10 ram yet? An was it the auto trans (48RE)
Is the map sensor scale being looked at or is it hard coded in the pcm? it would be nice to be able to go beyond 105kpa.
so what's the verdict? Can we write to JTEC+ ecm's or not? The website says 2001 cherokee 4.0L is supported, but the list here on the forum does not show it as supported. And this thread hasn't been updated by tech in 2 years.
I wasted a credit on a Jeep I can't write to. What's the deal guys?
me too, now my ZJ 5.9 runs on E85, cold start up to 35?F for now
Have a 05 SRT-10 Ram (RC) and looking to try loading the PID's for a Horsepower logger. Tried using the different Torque output channels along with RPMs using the standard user defined math to calculate HP but the torque channels won't display any data. Wondering if due to the 6 speed not having any sensors or just that the ECM doesn't monitor enough sensors to get what I'm looking for.
Anyone out there try this?
Hello everyone. I have a jeep wj 2004 4.7 pcm JTEC+. I turn off p0443 and p0136 p0158, the MIL lamp is off, but there are errors when reading with a scanner. What can be done about it?
