large (5sec +) delay between GPS and OBD Data
I was on a race track yesterday (HHR) and used TrackAddict to monitor GPS and OBD data and record Video. Viewing it afterwards on the Mobile I noticed about a 5 sec. difference between the actual position of the Vehicle and what it showed on the map. The Video and OBD-Data overlay (RPM, Gear, etc.) are absolutely in sync, however the GPS Data (Position, speed, etc.) are about 5 sec. late. I verified this in RaceRender and it showed the same result.
Analysing and editing the CSV manually (deleting the first 5sec. of GPS Data and rearranging everything else to match), it comes out correctly (except start and end points which need to be set manually then).
I'm using an OBDLink LX and an external High-Speed (10Hz) GPS via BT on an SGS5 mini with Android 4.4.2....
Any Idea why this happens? I'm happy to share my Data/Video if it helps..
Regards
STefan
