Transmission Shifting is slow and drawn out after relearn
Before I get into this issue.
Let me admit that I know just enough to get me in trouble.
Tuning is rather new to me.
I now know I should have not done what I did but I was getting frustrated and trying to learn.:confused:
I have SuperShredder. Super-Shredder is a 2016 AWD V6 Boosted Charger. :o
Shredder has a dyno tune for engine and TCM tune. More TCM changes were made after dyno tuning on the street.
On last dyno trip Shredder was having issues with throttle blade not keeping up with the pedal.
Pedal here-- Throttle blade here_. Tuner was able to get it better but it was still lagging.
But anyway I went home and it was bothering me so I was doing things to figure it out.
I later found out the issue with the throttle was the tazer.
But while trying to figure out the issue. I went to HP tuners scanner Beta software and did a reset on adaptives and then I did a slow and fast relearn.
Immediately after doing the relearns. My transmission started shifting terribly slow and lagging.
Especially at WOT.
It is no longer chirping tires and snapping into gear.
I will add that when I did the slow and fast relearns they said they were completed. However the green bar graph on the page said it was only 33% complete. So I waited and waited and nothing more happened.
I am convinced doing the relearn is the reason my transmission is not shifting right But I do not know how to correct it and I need HELP!:pray::worship:
:doh: I know I will get my balls busted for doing the relearn. I now realize that is for things like adding a convertor or changing the trans.
