08 mustang with Ford hot rod cams
HI
Just bought my second Mustang in 40 years. First was a 65 notch. Wow thing sure have changed. LOL I have tuned a half a dozen LS1 engines but first newer ford. Installing the Ford Hot rod cams and looking through all the tables and I am getting a little confused on the cam phasers. Ford gave me some Wot specs for cam degrees but many cam angle tables in the tune. Not sure on what tables to alter and exactly what line to change. Also should they be blended since Ford only gave me WOT values? Tried to find a few tunes here that show the Hot cams but not much luck. I can figure out all the fueling and timing just fine just want to make sure the cam angle values are correct before I start doing the rest. Any help would be great.
I see many Bama tunes mentioned on the web but I have HPT so would rather use this. THanks
