SOI and EOI adjustment and zoning
I run a decent size cam on and L83 curious to see if anyone could help me get closer to where it needs to be vs. the stock cal and my attempts. I?ve read other threads most being LS stuff, not Gen v material I understand what injection time is, but more so the zones and values I struggle with . It?s running lean I would like to see if it helps and otherwise I want to get the smell down (raw fuel), the caveats related to spark. I?ll post a tune file lately been running a stocking tune to start over with when I had my trans rebuilt.
Info
2018 Silverado 4 dr 5.3L L83 - 6L80 stage 2 circle d 3k stall - 9.5? 12 bolt duragrip posi unit w/ 4:10?s
FBO (Lt?s/y no cats, Airaid MIT/L86 throttle-manifold/Taylor wires)
DOD/AFM-Vacuum pump-Evap. Emission- rear o2?s have been deleted
225/235 rkspeed cam/Ls7 lifters/trunion upgrade/pac .660 valve springs /hardened pushrods/phaser locked CC full limited installed.
