2006 Crown Victoria P71 Speedometer calibration after 3.27 to 4.10 final drive change
Vehicle: 2006 Crown Victoria P71
Issue: Speedometer calibration after 3.27 to 4.10 final drive change
VCM Editor Version: 3.6.26
For Attempt #1 I changed the following
* Final Drive Ratio
* To: 4.10
For Attempt #2 I changed the above and the following
* VSS Tire Revs per
* To: 758.00
Each setting change did not alter the speedometer being reported via OBD or
on the instrument cluster itself.
I've tried a couple of variations on this, to no avail. ( Apart from drastically changing the VSS Tire Revs Per Mile )
Is there something I'm missing here?
For what it's worth the tire size I'm currently running is 225/60R16
Any input on this issue would be appreciated. Thanks!
